Saab Alcokey
edusaab
Saab Alcokey
Mensaje por edusaab »
Saab ha presentado un sistema de medicion del alcohol conectado al sistema antirrobo del coche, con el cual si el conductor al hacer el test este sobrepasa la tasa permitida en su region, que estara memorizada en el coche, pues este no dejara arrancar el coche. El sistema de momento es como el de la llave del 9-3ss, con el medidor y la boquilla y cuyo coste es de unos 250€, luego esta otro mas barato integrado en el coche.
Personalmente lo encuentro positivo, aunque un rollo patatero el tener que estar bufando cada vez que tenga que coger el coche. Aunque segun dice el articulo, sobretodo va dirigido a empresas con flotas de vehiculos para los empleados, es mas para un uso profesional.
http://194.18.30.108/smo/smopics/0/04236C.JPG
""""""Saab unveils Alcohol Lock-Out Concept
to discourage drinking and driving
Last year 29 percent of all drivers killed in car accidents on Swedish roads and 25 percent of all drivers killed in car accidents in Europe* can be attributed to drunk driving. To help alleviate this problem, Saab is now developing a unique, miniature alcohol-sensing device which will assist drivers in observing drunk-driving laws.
The Saab ‘Alcokey’ concept includes a small mouthpiece in the car’s key fob. A transponder communicates with the car’s electronic control unit, keeping the engine immobilised if a breath sample from the driver is found to contain alcohol above the permitted level.
Such a device could be made available as an accessory through Saab dealers and is currently under evaluation and development in response to increasing concern about drunk-driving, particularly among companies and public services in Sweden responsible for operating large fleets of cars.
Tests with a prototype for the Saab 9-5 model are expected to verify its reliability and accuracy. The concept is intended as a convenient and inexpensive means of measuring a driver’s alcohol level without the need to install more costly, fixed apparatus inside the car. In commercial production the ‘Alcokey’ concept would cost about 250 Euros, or a tenth of the cost of a fixed system installed inside the car. Saab intends to demonstrate the concept in conjunction with a safety seminar in Tylösand, Sweden, in August.
The ‘Alcokey’ concept is an elegant adaptation of existing anti-theft technology. When the driver presses the ‘doors open’ button on the car’s remote control fob, the alcohol sensor is also switched on. The driver then blows into a small mouthpiece at the end of the fob to provide a breath sample which passes down a small internal tube containing a semi-conductor sensor the size of a pin-head. The sample is then analysed and a small green or red light on the fob is illuminated.
If the green light is shown, the key will transmit an ‘all clear’ signal to the car’s electronic control unit. This is in addition to the usual signal the key always transmits to switch off the engine immobiliser. However, if a red light is shown, the ‘all clear’ signal will not be sent and the engine will, therefore, continue to be immobilised. The software instructing the engine immobiliser can be adjusted according to the alcohol limits in operation where the car is registered.
The current prototype ‘Alcokey’ is a separate unit, about 10 cm long and 4 cm wide, additional to a conventional Saab 9-5 combined key and remote control. In production, further miniaturization would allow both to be contained in a single, pocket-sized unit.
Mounting concern about drunk-driving in Sweden and many other countries has prompted Saab to develop the ‘Alcokey’ concept. Companies operating large car fleets, with employees driving a great deal on business, are anxious to demonstrate their social responsibility by having an alcohol-monitoring device fitted as standard. And in some countries, it may even become mandatory to fit them.
Saab Automobile’s President and CEO, Peter Augustsson, has taken a personal interest in the ‘Alcokey’ project. “Alcohol consumption is increasing in many countries and this often leads to a greater incidence of drunk-driving,” he said. “As a car manufacturer, Saab is keen to do what it can to help prevent such behaviour. We are an innovative brand and in that tradition the Alcokey concept is a very practical and efficient solution. It will help those who want to be sure they should only get behind the wheel when they are fit to drive.”
The Swedish National Road Administration is supporting Saab's work and its director, Ingemar Skogö, says he is pleased to see Saab pioneering such a practical aid to safe driving. “We all have a duty to discourage drunk-driving and this is a valuable initiative that other car companies should consider following,” he said.
* Statistics issued by the Swedish National Road Administration and EU European Commission. """""
'95 Saab 9000 CSE 3.0 V6 auto
PMI
Mensaje por PMI »
Me parece un buen invento, así te aseguras de no conducir con unas copas de mas, un rollo bufar cada vez de vas conducir, para flotas también me parece buena idea, supongo que la boquilla será desechable :?
kosovar
Mensaje por kosovar »
:!: :!: Asduriaaas, batriaa queriiiidaa :!: :!:
Y la versión "uropea": "Escoooocia de bis aboreeeeess" :!: :!: :!:
93 TID '00 azul, coupe, y que vete a saber como esta.
Er Torete
Mensaje por Er Torete »
Este invento seria la ostia, si una vez que soplas e inmoviliza el coche porque vas borracho. Hiciera la funcion inversa, es decir succionara, mas que nada para pasar el rato, hasta que te bajara el nivel de alcohol en sangre 8) 8) 8) :lol: :lol: :lol: :lol: :lol: :lol:
Saab 93 SS 2.2 TiD "El que me conozca que no me compre, no hay devolución, me suelo comer los tickets de compra"
-iceman-
Mensaje por -iceman- »
agusaab.... eres un guarreras... :(
ME GUSTA TU ESTILO!!!!!!!!!!!!!! :lol: :lol: :lol: :twisted: :twisted: , seria muy util en los semaforos, y la cara de los demas cuando te vean to feliz detras del volante JAJAJAJAJA
SAAB 9-3 SS TID Aero
SAAB 9-5 AERO (230cv)
Passat TDI 130 CV
saab993
Mensaje por saab993 »
:shock: Así que habrá que hacer soplar a alguien que pase por la calle, para poder arrancar el coche, y llegar al hotel a domir la mona :wink: :lol: :lol: :lol: :lol: :lol:
Última edición por saab993 el Vie Jun 18, 2004 9:11 am, editado 1 vez en total.
Er Torete
saab993 escribió::shock: Así que habrá que hacer soplar a alguien que pase por la calle para poder arrancar el coche y llegar al hotel a domir la mona :wink: :lol: :lol: :lol: :lol: :lol:
Bien pensado, hecha la ley, hecha la trampa :wink:
O tambien ha de coincidir con las huellas dactilares :roll: :lol:
alvar9000
Mensaje por alvar9000 »
o dejas el motor encendido ante de irte de copas y asi ya no tienes que soplar.
Un saabludo
Toyota Auris Hybrid
VW Passat GTE
saab993
alvar9000 escribió:o dejas el motor encendido ante de irte de copas y asi ya no tienes que soplar.
Un saabludo
...ni los ladrones tendrán que hacer el puente :lol: :lol: :lol:
alvar9000
joder, si nos ponemos con esas finuras no vamos a llegar a ningún sitio :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol:
Un saabludo
Toyota Auris Hybrid
VW Passat GTE
edusaab
estos ya lo tienen en cuenta..................
""""""Some drivers who have had too much to drink could try to fool the analyzer by having teetotaler friends blow into it, Saab's Smith acknowledged. "It's not fool-proof."
But some engine-locking devices used by U.S. courts for habitual drunken driving offenders have built-in voice recognition systems that prevent friends or compressed air devices such as balloons from being used to start the car.
"As they (Saab) develop this further, they'll be working on ways to stop people from circumventing the system," Smith said""""""
Ellos mismos conocen que el sistema puede ser evitado mediante que sople un amigo, por ej. pero en USA las cortes judiciales para temas de conductores borrachos utilizan sistemas basados en el reconocimiento de voz y ademas evitan el engaño si este se intenta hacer pasar el test mediante un globo lleno de aire. Los de Saab ya estan trabajando para introducir sistemas antiengaño.
que no os vais a libraaaaaaaarrrrrrr :lol: :lol: :lol: :lol: :twisted: :twisted:
